When you say you tested it, how did you test it exactly? What motor/ESC are you using and what are your timing settings? What pinion are you using on the motor? And did you ever go above 25% throttle? The more information you can provide (including videos of how you tested) will help out a lot.
I bought this heli from helidirect store and everything is stock
Align T-REX 450L Dominator Super Combo 6S with Microbeast PLUS - HeliDirect
The motor is 460Mx brushless, the pinion is 11T (3.5mm).
The way I test it was just turn on and try to fly .. That's it ! I guess the throttle was no more than 25% .. I tried very slow. I changed the settings d/r expo
Aileron, elevator and rudder to 80% and expo 45%
The throttle curve 0,20,35,55,85%
Pitch curve 0,20,45,60,75
But I turned on the heli for just 5 minutes I guess. Also after 20% throttle the tail was shaking like crazy than I turn off the heli.
