well there is some up and down movement on the shaft but its very less.like i said its stops(wobbling) way before midstick.maybe you could give me some checklist before i fly?
That is actually quite common on a lot of the Align heads. My Pro has the same slack, but not that bad. Maybe see if you can get a piece of aluminum foil in there. Grab a little water or something and wrap the foil around the shaft 1 time and slide the head on. If there is still play, try another piece until the slack is gone.
The split lock is the better design. It allows the head to clamp down on the shaft like it's supposed to.
