If you like align servos then you'll like the Savox. MKS 92A are the shiz and if you can front the bill on three of them then go for it. The MKS servos are faster at 4.8 volts then the Savox at 6.0 volts. Almost all the Protos kits that I saw on youtube are outfitted with MKS all around but they used the DS95 for cyclics and the 95i for the tail. Good luck, I almost considered this but did not like it based on the images I saw. It looks way to simple for me. Maybe you'll change my mind on this kit.
If i could afford the 95I, i would get them. But at $50 a cyclic servo and $80 for the tail, it way too much. I have time to change the order if i want the 92's but i have seen these birds with Align and savox in them. If i was a 3D smack pilot I would be more concerned, but for the time being, I think they will do.
As for being way too simple, that is the benefit. Less to break and easier to fix.
No tail boom support? You are the tail vibration king and that may bite you lol. Looks like a bitchin (yes Stokke, you can say that on here) heli and I can't wait to see you putting it through it's paces.
Remember Tony, this is a 450. It has a 500 size tail boom. This is one beefy bird
Never heard of it before! Lol
Thats because its new Sam
So guys this comes with a compass motor. I'm going to buy the YEP 45A ESC and a couple of Nanotech 6S 1200mah packs to start with, then when i have some more cash i will get a couple of Gens Ace 1400s
The only other thing i need to decide on is the FBL unit. Should i just get another AR7200BX, or try something else like the Ikon? If i get the Ikon, i will probably put that on my 600 and use the BeastX for this. What do you think.
