Heliman450
Hi Steve, it does have the 600 boom and was always a bit tail heavy even with its original 550 boom. This time, I fitted the shorter tail rotor blades (85 mm not 90 mm) rather than the longer ones from previously. I've also done some calcs to find out what percentage I need on the throttle to give the equivalent tail rotor speed with the higher gear ratio. With zero pitch it needs 83% throttle just to achieve the same revs on the tail. Therefore, it will need probably up to 100% when load comes on with higher pitch demand.
By any chance do you have the dimensions of the bigger landing gear? I was also considering something along those lines but don't have access to one to take the measurements. My local supplier is stocking fewer big heli parts as their business is migrating towards Rc-Cars. I would be inclined to go for a complete switch rather than only the rear so that the heli maintains a level stance on the ground. I suppose it doesn't matter too much for you guys who just lift off into the wide blue yonder and perform magic
