1. Guest, Thank you for visiting Rc-Help. Please do NOT post tech questions in this section, post them in the Tech section instead. Thank you.
    Dismiss Notice
  2. If you would like to get rid of these banners and the ads within the posts, all you have to do is sign up and they will go away!
  3. Welcome to Rc-Help, are you here looking for the PDF Plans? They are located in the store in the tab above, but you must be signed in to access that part of the site. It only takes a second to sign up!
  4. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Opinions On This Subwoofer
Discussion in 'RC-Help Lounge' started by bigone5500, Jul 1, 2018.
< Crossover Parameters Pioneer Deh-s6010bs | Replaced The I7 Lappy Fan >
  1. bigone5500
    bigone5500 Well-Known Member
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    I am looking to add some richness to my audio system in my truck. Years ago I was into car audio systems but have no clue about the quality of stuff now. I used to own Fosgate and Orion products but sold them off many years ago. They were top notch. The last thing I had, about 5 years ago was a power acoustik PA1200 and two Sony P5 10" subs. That stuff was alright. The PA amp was pretty good. Alas it has been sold off years ago. The only thing I have left is some wiring and a Fosgate Punch 120 aII amp. All I want to do is add a little low end to what I have factory in the truck. Right now I'm looking at this subwoofer which looks good and can handle what the amp can put out.
    Simple question is has anyone here had any dealings with power acoustik audio equipment in the past 5 years or so?
    GW3-10 | PowerAcoustik
  2. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    FYI: I am not looking to play music for people 2 blocks away. I am not trying to vibrate quarters off my hood...LMAO!!!!!!
  3. Tony
    Feb 21, 2011
    37,148
    1,458
    113
    Never even heard of them. For some reason I see you doing this...... Or trying to lmao.....
  4. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    Oh no. I'll never put that much power in there. That's just plain stupid. I work in too much noise to do that. When I was younger I tried but didn't have enough money for the equipment.
  5. Tony
    Feb 21, 2011
    37,148
    1,458
    113
    I think you should get these...
  6. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    Uh...no. I have back trouble as it is. Those would put me in the hospital for sure.
  7. Tony
    Feb 21, 2011
    37,148
    1,458
    113
    It would be like a massage every time you are in your truck lmao.
  8. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    Go big or go home...
  9. rdsok
    rdsok Well-Known Member
    Sep 11, 2011
    1,822
    70
    48
    Norman, Ok USA
    Equivalent to about 312.5w at 8 Ω ... :D
  10. Tony
    Feb 21, 2011
    37,148
    1,458
    113
    You run subs at 1 or 2 Ω. 8 is for mids and highs or home audio.
  11. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    Dyno tests show it to put out 1000w RMS at 4ohms. That's what I'll be wiring it at for now. If I get another sub, which I may not, I can wire it at the same and get more sound volume...we'll see. However, I'm going for quality of sound and fullness. NOT SPL.
  12. rdsok
    Sep 11, 2011
    1,822
    70
    48
    Norman, Ok USA
    On my band equipment... it all ran at 8Ω .... I also never ran car stereo's below 4Ω when I was setting them up either since it worked the amps so much harder at 2Ω or less.
    I used a 700w amp on two 18" speakers, 500w on a pair of 15" mids and another 500w on the horn tweeters. I used them in clubs, bars and even outdoors ( a little weak for outside but they still covered a few acres well enough ).
    For home stereo... I don't see the need to exceed much over 500w. For a car/truck... a couple of hundred watts should be plenty. I'm more interested in the precision of the sound than the amount of air I can push... 90-95 decibels or higher is going to start to damage your hearing.
  13. Tony
    Feb 21, 2011
    37,148
    1,458
    113
    what?...
    lol, now you are sounding old lmao
  14. rdsok
    Sep 11, 2011
    1,822
    70
    48
    Norman, Ok USA
    It's not so much sounding old... as hearing ringing constantly .... ( something 15 yrs of running sound for rock bands may have had something to do with ). Basically, I've listened to way too much over 100db sound for too long and still pay for it.
  15. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    @rdsok OSHA states that you should wear hearing protection at 85 db or above. Where I work, we use large fans (200hp) which create very high db. Sometimes we have to wear earplugs and muffs. Some of those sound systems can produce sound levels above 150 db. That's insane.
    Noise-Induced Hearing Loss
  16. rdsok
    Sep 11, 2011
    1,822
    70
    48
    Norman, Ok USA
    Yeah... just more of that "more is better" mentality which really has nothing to do with actual audio fidelity.... lol
  17. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    I'm trying to put my radio in this truck and this has got to be the most difficult and painful install I have ever experienced. A 2008 Ram 1500 stripped down (ST) model. No extras, no power anything. It does have cruise control though. I bought a $13 harness from Advanced auto and it wouldn't work, the wiring was different. I bought a harness from best buy and it seems I need an interface box to use that one. I'll be returning the harness and running wires from the battery to power the stereo and forego any harness adapters. I hate these newer vehicles. There is just too much to them that causes people like me to rip their hair out.
  18. Tony
    Feb 21, 2011
    37,148
    1,458
    113
    Definitely do not run directly from the battery. All you should need to do is get some small spade connectors and just wire it into the factory plug.
  19. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    True. Didn't think about what I was saying...LOL! Well, one wire should be powered at all times and the other switched. Just look at this crap. The new plug for my stereo is to the right.
  20. Tony
    Feb 21, 2011
    37,148
    1,458
    113
    Looks simple enough. But I love doing wiring like that lol.
Share This Page
