Beckmann Josh
Im setting up my servos when plugging them in to the reciver, is the THRO the same thing as pitch?
One of the front servos, left servo to be exact will plug into aux1 and right front or aileron servo will plug into aileron channel and ESC plugs into throttle channel, then aft servo or elevator servo plugs into the elev channel
If you are using the 3gx unit you will be better off running the sats and not using a receiver, alot less wiring and easier install,
T-rex 450 pro 3gx with a spektrum raido/reciver
