I took my T-Maxx out for a while today have to get used to it it is pretty fast get a couple cartwheels today with it flip it upside down and didn't break anything
The fuel has oil in it. This oil doesn't have friction modifiers that will allow the roller bearings to grab onto the crankshaft starter and will cause it to slip. There is special one way grease that you need to use.
I put the one way bearing on the shaft and it spins One Way only does that mean the easy start gears are one of the easy start gear for bad the plastic gear has a lot of wear on it
