Trucks I play with my T-Maxx
The OWB is a known issue on these. Take it off and clean out the fuel oil that has gotten into it.
The fuel has oil in it. This oil doesn't have friction modifiers that will allow the roller bearings to grab onto the crankshaft starter and will cause it to slip. There is special one way grease that you need to use.
I put the one way bearing on the shaft and it spins One Way only does that mean the easy start gears are one of the easy start gear for bad the plastic gear has a lot of wear on it
Only you will be able to tell that. I can't see it. If the gears are stripped, then that is likely your issue.
Have to get a new one way bearing so when I did that I went ahead and ordered the easy start module and new Traxxas EZ start wire harness
