EyeStation
I could not hold off any longer. The mini Quad Racing just looks too much fun to miss out on.
Watching the builds of various mini's around here I opted for the Wasp 280. I downloaded the manual before I bought it and saw how simple and unique the design was. But for me, a wooden frame means a disposable aircraft frame.
When I saw there was very little glued in this frame and the repairs would be easy, I had no more excuses.
ESC's and CC3d OpenPilot cane in on Thursday. Had a 6 ch receiver already, so spent THursday night and Friday programming the DX6, and running through the OpenPilot GCS software. Updated the controller to the latest software and waited for Saturdays postman.
Saturday did indeed, bring the goods. Got the frame dry fitted and went through possible electronics layouts in the frame. Installed the Sony 600 cam into the nose. Put the FPV TX and PD board into place. Dropped the #808 Key cam above the sony on the platform provided and stepped back to see this.
I guess it's time to go off to the paint booth.
Like TaSaJaRa, I wanted that faux Carbon Fiber look using the supplies I had at hand.
Settled on FasKolors Fasescent Purple as the base color getting the CF pattern with the drawer liner and Fasblack.
Let it dry up a bit and reassembled for another look.
Spent about an hour setting up the CC3d, which was a breeze to go through. Found I had one motor that I need to swap wires on. Resoldered them and dressed the wires. ESC servo leads shortened to length.
Now, time has come, Full battery, fully programmed Tx. Time to put the props on and see what she does.
Found out the default "unarmed" programmed into the flight controller needs a trigger to turn off.
Plug the usb cable back in and find that tab on the software. Click, send, disconnect, back to battery.
Powered her up, throttle to low, Yaw Left, and she's armed. Wipe the sweat from my hands and go for lift off.
About 2/5 throttle she starts to rock a bit, "pay attention to the roll" I tell myself. Give it a couple twitches of roll left and right to make sure it responds properly and she's good on that axis. Next a bit of pitch for and aft and she's correct there too. up to 1/2 throttle and she lifts off in a nice whirl of sound and air. Straight up with increase. Need any trim right? Hmm, no.
Not pitching forward or back either, wow. Ok lets see, forward stick and she gently goes forward. slight tick back on the elevator and she holds right there. Nice.
OK, lets see what the rudder does. Get it up about chest high and left yaw for 1/4 turn. holds!
1/2 turn Yaw Right, flat yaw and holding. Outstanding! and the first attempt at setting up this control board.
Well 2 batteries went in and got about 7 minutes hover, slow forward flight out of a a 3Cell 1300 mAh Nano-Tech that hasn't been used in 7 months.
Time for bed. Much work to to tomorrow to finish this frame off.
Sunday starts with another dis-assembly and the the cleaning and routing of cables. After that it was time to soften up the look of the Faux CF.
Not really liking the checkerboard look, and realizing my Lexan painting routine does not work for bottoms up painting, I set out to mute the outer shell with the Fasescent Purple, some Faspearl Black. With the frame stripped of electronics I put it together and started to paint the exterior while assembled.
After finishing the airbrushing part, I set off to Ace Hardware to get some Urathane spray to gloss up the finish.
Dried the pieces as long as I could and started the final assembly. Used Loctite Fun-Tack Mounting putty to put the esc's on the lower platform.
performed final wire sizing for the ESC power. Hot glue to secure the wire connections at the ESC. Mount all the FPV equipment similarly to the canopy. Final position for Rx and antenna set.
Now, this is what I got going on.
