wolfman76
I never built Cb antennas but i use own a Royce 619 base cb with a 30ft 4 element ground plane antenna... It is the same basic concept as a ground plain antenna the more elements the better same as a CB for the fact that more elements going in different directions the better you receive the signal from others it is exactly the same. On a sat antenna you have 2 elements so just using one sat with the 2 sticking straight out the side so you are limited to the it only picking up signal from the TX from only the sides but with 2 says it doubles the ability of the heli to receive the signal wether it be from the left side of the heli or right or from above or below almost liked the helis sats are surrounding it in a 360° rx bubble so to speak. Dude trust me and Tony the extra elements of the 2 sats makes all the difference in the world.. I actually use to talk skip to people from Texas from Indiana with my ground plain but only because i had the 4 elements off of it without the extra elements i wouldn't have been able to do it and my base radio was completely stock had not been clipped or tweaked.. Hope this helps you understand a little better.
