jcfernan51
I took the heli up today again and noticed that the tail wags when I command collective pitch or it is unstable when the wind picks up. I watched the set up video again, both basic and parameters and I am confused as to what to adjust.
1- How do I know when I am in Rate or Heading Hold (HH)? Okay this is my understanding, when in HH the tail try to hold its position. If the heli rotates left on its own (wind induced) the Gyro compensate in the opposite direction unless it is been commanded in that direction. I know if the LED is blue after initialization it is in HH which is how I should fly. Mine is always blue but is there a switch I am supposed to set to switch between the two modes or once the gyro is set up is always in HH? Is there ever a time when I want to use Rate mode?
2- Once the basic set up is completed the manual enters "Dials and Tail Gyro Gain" this is where i am kind of loss. It starts with the three dial settings, where #3 is the one I think I should play with to try to eliminate the wagging during pitch pump. But then goes into parameter setting D - Tail Heading Lock Gain which state
1- Start with Heading Lock gain set to low or very low tonight I adjusted mine to Low and maximize the tail gain in your transmitter. Where in the transmitter? is this the Gyro menu setting? If it is, what value should I set the 3 position switch to start?
2. Increase the Heading Lock gain in the AR7200BX until the desired result are achieved.
Then there is Parameter F. Tail—RevoMIX I watched the video and I understand what is does. While watching the video I changed it to Low but I am going back to factory before I fly tomorrow. I don't want to change to many parameter at one time and I am not convinced this has something to do with tail wagging or wind instability.
As you can see lots of questions. I will continue searching the forum for answer.
Thanks in advance,
Juan
Thanks in advance,
Juan
