General 450 Pro 3GX V2 Still cant get it in the air!!!!!
Graham Lawrie
IMAG0851.jpgIMAG0860.jpgIMAG0852.jpgIMAG0854.jpgIMAG0855.jpgIMAG0856.jpgIMAG0857.jpgIMAG0858.jpgIMAG0859.jpg
These are the pictures of my girl at mid stick. As you can see, servos 90, main rotor level(zero). Tail rotor blades aligned. I did the 3GX set up and all looks ok. when i spool up she wants to go right and flip over?? I tried compensating with a tiny amount of cyclic which stopped the tip over, got to 3/4 stick and she never even lifted off. Any help as always appreciated. I will add a video of what is happening.
coolgabsi
Super Mod & DEAL KING!
Sounded Like in the end you did chop the throttle and the pitch went negative all the way. My bird sounds like that too as I tend to chop my stock down after throttle hold
I know you have done all the setups. But to confirm
Left stick up is swash up and left stick down is swash down ... Correct ?
And before spool up have you checked your gyro correction direction? Tilt bird right swash wants to automatically go left (not right) and vice versa
Same til it forward swash goes back to correct...
I would guess the correction direction to be an issue but of course you know better what you have there. Let us know! :)
Fly safe!! :) have fun!
john2012
Banned
i think if it is rolling to the left or right you will need to check you swash and recheck if it's level i would start there,and or your settings in you tx
Graham Lawrie
Hi super bad, i have not changed the thro/pitch curve settings and it is a DX6i
All as you have said, i think it may be my TX settings?
Yes I would check for level. Believe it or not it does not take a lot for the heli to react that way.
Then I wouild check to see if it is correcting in the right direction:
Tilt heli forward = swash tilt back
Tilt heli left = swash tilt right
Tilt heli back = swash tilt forward
Tilt heli right = swash tilt left
breeze400
Spagetti Pilot
The other thing to check is with the head and blades on check that the pitch pf the blades is right. If your not getting positive pitch you won'y lift off!
heli-maniac
need to set the pitch curve
around 45 47 55 75 100 on the the tx in normal mode
the lean to the left is normal for the heli you have to give it alittle right on as it starts to lift like that that is how my bird takes off
Graham Lawrie
Hi Superbad, thanks for this. I have just watched Tonys video on the DX6i and have set up mine the same. I have put same pitch curve in. I hope that it has been the TX settings. I will try a spool up and see what happens. cheers Graham
Hey Graham,
If you have Skype we can chat tomorrow if you want. I'm free all day. Maybe we can figure this out.
stokke
Is your swash level when the bird's sitting on the ground prior to take off?
Have you checked the functions Matthias described?
Are there any trim (not sub trim) activated?
Have you checked that each specific servo responds to the specific radio inputs?
Have you checked your gain pots?
Have you flashed your 3GX unit?
Graham Lawrie
Done everything apart from gain pots and dont know what flashed means?
Hey Graham,
Hi Lee, That would be great, but i am back to work tomorrow, maybe at the weekend if i dont have any luck. I have set up my tx with Tonys video. thanks for the offer.
stokke
Have you upgraded the 3GX's firmware? (flashed)
Also, you can try taking of the blades (main and tail), then spool it up and watch what happens.
Also, check that there's no CCPM mixing enabled.
Graham Lawrie
I have not used the 3GX software, just done it on the TX. Also i just spooled up in the dark outside with Tonys settings and that has been the best so far. But the tail started spinning anti clock wise as i went past half stick.
I have found a setting on the DX6i, MODULATION, what should this be set at? I think i am very close now, Tonys settings have helped.
Really close i think now:)
heli-maniac
sorry i have not been much help been in and out all day hanging Christmas lights im like my helicopters and dont like the wind
