  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Other Traxxas TQi Bluetooth issue
Discussion in 'Transmitters & Receivers' started by bigone5500, Sep 26, 2017.
< DX9 Video Suggestions | Dx9 Charging Issue >
  1. bigone5500
    bigone5500 Well-Known Member
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    I can't connect to my galaxy S8+ with the Bluetooth module. Does anyone e else have this issue? I have contacted traxxas about this but haven't received an reply yet.
  2. Tony
    Feb 21, 2011
    37,146
    1,458
    113
    This is a new one to me. Didn't even know they had BT on these things. What does it control or monitor?
  3. Tony
    Feb 21, 2011
    37,146
    1,458
    113
    Looks like you just download the app, open the app, push and hold the button on the back of the Tx until it flashes, then follow what is on your phone and it should connect. Will more than likely have an update when you are done so just update it and you should be good.
  4. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    Connected immediately to my iPhone. I updated the firmware and still no go.
  5. Tony
    Feb 21, 2011
    37,146
    1,458
    113
    So you have it connected? In the first post you said it would not connect. Make sure the truck and Tx are on and that they are both bound.
  6. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    Will not connect to my S8+. Connected to my work phone, iPhone 6S.
  7. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    Probably going to be an Android issue.
  8. rdsok
    rdsok Well-Known Member
    Sep 11, 2011
    1,822
    70
    48
    Norman, Ok USA
    Does your Android see the device when you are in the bluetooth menu area? If so, it should prompt you for a pairing code if it can't automatically connect after you've selected the device in the BT menu... then you'd use the pin code they mention in the manual for the device.
  9. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    It doesn't show up anywhere.
  10. Tony
    Feb 21, 2011
    37,146
    1,458
    113
    I know this is an obvious question, but is your bluetooth on in the phone? If it is, turn it off, restart the phone and turn it back on. If that doesn't work, try connecting something else that is bluetooth, like a headset to it and see if that works.
  11. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    I got a reply from Traxxas. Here is the response:
    I will register my truck and send them the info. I am assuming they can flash it and make it work.
  12. rdsok
    Sep 11, 2011
    1,822
    70
    48
    Norman, Ok USA
    Not to be picky really... but technically if it could be flashed, then that would be firmware. I suspect this is a hardware change to address the problem.
    FWIW... I've got some pretty old BT headsets and they all still work ( of the ones that still take a charge ) and pair with my Android which is running v7.0 and using the latest security updates available for it... So they must have done something a little out of the ordinary on their hardware if an update breaks it from working somehow.
  13. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    This is the only bluetooth device that I have had trouble with aside from trying to communicate with a *shudders* iPhone.
  14. rdsok
    Sep 11, 2011
    1,822
    70
    48
    Norman, Ok USA
    While I don't know their reasoning... Apple has always limited their networking capabilities and they usually only do it "their way" instead of following standards that others ( Android, Linux, Unix and Windows etc ... ) use. So when it comes to networking, you don't really want an Apple/Mac product unless you don't need robust connections.
  15. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    I talked to traxxas today before I sent my module in. They explained that the latest security update in Android caused their module not to work with the OS. A simple reflashing will fix the issue. It cost me $3 to send it via usps.
  16. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    My module should be in McKinney Tx tomorrow. Hopefully they will have a fast turn around and I will get it late next week.
  17. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    Got an email today (2:37pm) and they have finished with my module. It will probably be at my house either wed. or thurs. Nice!
  18. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    Got my module today and it works fine. Paired with my phone immediately.
    rdsok likes this.
  19. Tony
    Feb 21, 2011
    37,146
    1,458
    113
Share This Page
