Well guys, this is what happens when you work, and get really bored. These I'm sure are not finished, but I thougt I would post them up for you guys. If you want to build it, let me know how it works. I would run an alpha 370 with a 10x4.5 prop, or an alpha 400 with a 10x6 prop. Battery should be a 2200mah 3s and standard 9g servos. One thing that is not on the plans is you will cut a hole right under where the wing is on the fuse, and glue the piece you cut out to the bottom of the wing. This will tie the two pieces of wing together, and it will let you have a wedge to keep the wing in place. Just run a couple rods through the fuse with backing pieces for rubber bands, and your wing is set.
Like I said, this is a work in progress because I was bored. Let me know what you think.
Please click on the store button above to download the latest plans!
