Yes the fbl does the mixing for me so I have to setup with no mixing. ER9X has templates that you can use right in the firmware. You go to the template screen and they have a set of basic presets for a few air craft. It makes the setup a little easier if you are going the flybar route. I had to find a basic file on the open9x forum that gave the very basic setup that can be modified to suite my needs and right now [without a heli present] it seems to be working.
I tried to set up a file from scratch and could not get the stick inputs to map to the right channels. When I set up my FT Versa with elevons I got it to work like a charm with my servos on channel 1 and 2.
