450 Tail grip washers
that notion had crossed my mind..but thought jb was fer metal parts only?..ill have ta pick up some n try it then..thanks for the heads up rider!
in the bottom of the box where our info is..what does rep power mean? jus curious
Cut you a little piece of plastic, just wide enough as servo itself...
Length don't matter, but try to keep it about 1 inch long...
Lay it over the edge of a table with half of it hanging off....gently put some heat to it...
Bend it to 90 degrees, now lay it onto the side of the servo with just a drop of JB weld on the
bottom, pushing it butt up against the broken tab.
Now lay a thin coat of JB weld over it/covering the edges of the
Piece all the way up to an around that and the broken tab
Let dry a day, then drill your holes for servo screws....
I can post a pic of the servo I did if that'll help
explain it better...
What you'd need to do is use a little peice of plastic on the other side you can't use too thick a plastic or else your "new tab would be too thick...the plastic pieces are going to be your new tab
