It's ok
One thing to remember please don't fly with governor off with those settings. Always governor on.
Headspeed : I would stay at or around 2100 or less
What's your gear ratio? I forget the gear ratio of a trex 600 ... If I am right your powerband for the engine is 1.9hp at 17000 rpm.. Means divide that by the gear ratio and add about 100 -150 to it and that gets you your headspeed. Just hovering you can make your heli very stable at about 1900 rpm ... If you are gonna do more then keep at 2000 ...
Rce 600 comes with instructions for throttle curves.. Follow that.
for Tx setting on throttle curves.
Just answer this for me once...
is that your heli in that pic above? If so aren't you using a 3gx .. I have been so confused.. Lol let me know
Also one thing... Throttle hold will need to come up from zero to a little higher to match your idle setting on the trim tab on throttle so when you hit throttle hold the engine doesn't die but keeps idling... And throttle CUT will be set on another button that'll kill your engine when needed.
Gaba
