General Servo Positions help
Slobberdog
Just thought I would post this up, I don't know what many people do when they are building their heli's but here's something I think is an easy way to now where the bundle of wire that go into your receiver come from, when I bult my 450 I put tags on each, but I think this looks a bit better,
After I decided where my servos best fitted in the airframe due to arm fit and centre points, I then had a black marker, starting at the aileron servo I marked it with on spot at the servo end the one spot at the plug end, then going around the others I did 2 spots 3 spots and 4 for the rudder,
Here's a couple of pics as they say they speak a thousand words,
I thought this was a simple clean way to know each wire when the little bundle needs to be plugged in,
Hope this helps some one, it was for me!
pvolcko
Nice. I've run into trouble sorting things out at the end of a build. Tug method to figure out what was what. I like this though. Could also go with color coding single dots if you had the colors. Nice tip!
