one thing you should know is that setup is the same regardless of the air frame, electronically that is. Servo are level, swash level at 0 degrees, blades are at 0 degrees while at 0 degrees of pitch. Every air frame is the same regardless of the fbl. its all part of the mechanical setup.
As for the software side just do what feels good. There are the few things that need to be exact and do those but the rest is general and not air frame specific.
