450 SAB 380 Head Setup (Video)
USAF_Ret
Does anyone know of a video to that walks through the head setup of for a SAB 380? I have looked for several hours on the web but can't seem to find one. If it makes any difference I am using a AR7210 for the controller.
USAF_Ret
Just follow the AR7210BX setup process, there is nothing about the G380 head that needs any different procedure.
one thing you should know is that setup is the same regardless of the air frame, electronically that is. Servo are level, swash level at 0 degrees, blades are at 0 degrees while at 0 degrees of pitch. Every air frame is the same regardless of the fbl. its all part of the mechanical setup.
As for the software side just do what feels good. There are the few things that need to be exact and do those but the rest is general and not air frame specific.
