As some of you know, I purchased back my old HK450GT from Sam (Breez400) adn have been flying the crap out of it. Well, today I received my order from amainhobbies with a LOT of parts for it, and another 450 to be named later.
The parts for the HK450GT are as follows
Helical main gear
3.17 helical pinion 11T (low head speed, but the motor is underpowered so adds more torque to the head)
auto gear
tail drive gear
front tail boom mount (solid v3 mount, nto the block with seperate drive gear holder)
belt
tail boom
tail shaft
All of that stuff is Align. As I always say, if you have to replace anything, do it with Align if you are working on a clone. Adn that is what I'm doing. I decided to go with the helical gear mostly because I had 3 coming, and I was only going to use one. Plus, the pinions are cheap. Speaking of the pinion, they are aluminum and VERY light compared to the brass that came with it.
The reason I'm doing this is 1. the drive gear that it came with was oblonged and not runnign true. But, I couldn't find the drive gear that I needed, so I converted this over to teh v3 drive system and block. Best of all, it's a direct swap.
I should have ordered the Align one way sleeve that goes in the one way and also in teh auto gear. When I go to replace this auto gear or whatever, burn up a one way, then I will order the sleeve. I had to take a hammer to this one just to get it to fit. not exactly ideal lol.
Another reason I'm doing this is I think I'm too used to TT heli's and the way they free spin. And I wanted to put a good belt on this thing to test it. After I put the align belt on it, it was TIGHTER lmao. Talk about a fail. But, the belt needs to break in and get rid of the bends that it had when packaged. We will see how it does.
My next step is to replace all fo the bearings. Now I know I said I was going ot keep this all clone, but I just couldn't do that. I have to have quality and that is what I'm doing, making this a quality bird. Just wait until you see the next one hehe. I think you guys will like it if you are still into building clones.
I will post pictures after I'm done with it adn show you all of the parts that I replaced, and yes, a flight video as well. For now, here is the before flight video. It's just a random video that I shot of the heli when flying it around.
Remember, this is the before video that I just picked at random.
Flying & Glasses Audio Test - YouTube
Helical main gear
auto gear
tail drive gear
belt
tail boom
tail shaft
