Hello,
After watching your video, I see you are using Afro ESC's with I assume SimonK firmware. If so, I have recently learned that for those esc's with SimonK firmware, you should have the esc type set to pwm sync 490. Also, after calibrating the esc's you should power cycle the board. Additionally, you are waiting too long to hit the stop key when doing the esc calibration step in the setup process. You should hit "stop" immediately after all the esc's beep for the first time. It sounded like 1 or 2 of the esc's were in the second step of configuration when you hit the stop button.
I hope this helps as I am learning the CC3D, CC3D Revolution and CC3D Atom right now and am having an issue with the Revolution.
Scott
