precociousmouse
Hi all!
Hope someone can help as I have got to the end of my first Quad build and am having real problems getting the motors to spin up in libreflight.
The build is a Diatone ET200 frame with a cc3d FC, 20A Afro ESC linear BEC and a set of multistar elite motors. The TX/RX is a fly sky fs-t6 with bundled receiver.
My problem is that I am going through the vehicle setup in libreflight, and everything is fine until I get to the ESC calibration page. I follow the instructions and get to the point where I plug in the lipo but the fourth motor (SW) connected to channel 4 on the cc3d spins erratically and none of the other motors spin. The ESC also beep and the blue led on the board flashes once a second.
I have tested the voltage at all the points on the distribution board, as well as the +/- points on the ESC -> motor side and they are ok. I also tried switching another motor through to channel 4 on the ESC and that then spins erratically so I am assuming it's not an issue between the distribution board and the motor. I also know the receiver has power and when I checked the sticks on the input configuration they go from full up to full down.
Except, also the yaw control doesn't move.
Arming settings are set to always armed just to ensure that this shouldn't be the problem, but I'm getting really frustrated trying to take to the skies
Hope someone can help, so I can join my fellow pilots in the office (but they all bought pre-built quads and where's the fun in that? )
