Spektrum Pitch question
fran11784
Today something strange I think, I was running up my 550 and the pitch wouldn't move but had full control of everything else. I don't know what I touched to fix it. Does anyone know what I could have done to cause that? I think I moved the gyro sw but no sure. It's a DX7s
Tell us more about your helicopter. What gyro and receiver are u using? Did you mean you had no swash movement as you moved the throttle stick up and down but the swash responded properly to cyclic inputs?
has this just happened? or have you always had this problem? check your pitch curve .... and check your pitch Swash % those are the things that control pitch.
I would try all the things Westy suggested + rebinding the helicopter. It's also a good idea to go into MONITOR menu in the DX7s to make sure the TX is putting out the correct Pitch signal.
Also .... check to make sure that your wires have not come out of AUX 2 or Aux1 (which ever the 7200BX controls pitch with ) try unplugging and reconnecting the servo plugs. (especially the AUX 1 and 2)
servos not siezed ..... as the Cyclics are all working .... just not the mixing for the pitch control - Unless I have mi-understood the post from the start.
Yeah, that's an odd one. You waited for it to complete it's initialization and give the happy wave of the blades? I've never interrupted it but maybe spinning it up during init will result in that? Or as mentioned, maybe an intermittent bind?
Pitch curve was just linear. I can't seem to duplicate it. Ever hear the expression, "if it at broke don't fix it"? I upgraded to this DX7s from A perfectly flying DX6i. I ask my self, why....lol
they are good !!!!!
are you looking for Throttle curves? or Pitch curves or both?
Go to TOny's heli help section ... all will be revealed...1!!!!
Bout to toss this rx in the trash can. This morning I was out with my 700. Range check ok. Lifted it into a hover and the rx started beeping at me. I set it down and the telemetry said 255 holds, 11 frame loses and 192 degree esc temp. Reset and try again but same thing. So not to ignore it I took it home and check everything and found nothing. What the hell? This thing has been one thing after another. Sorry, just venting
TX I ment
Have you tried rebinding the RX/Telemetry to your radio? I find most weird radio issues are solved by rebinding.
Yep, tried everything. I've been trying to resolve this for two weeks now on the phone with the Horizon people. They are great people but they just don't know whats wrong. Thought I had it fixed but no. I most likely will be sending the whole thing in for them to look at. I can't believe I'm the only one who ever has used a AR7200bx and a TM1000 before?? They clam they have never gotten a call with these two pared together. Anyhow, when I get it figured out I will post. Hopefully save the next guy some hair pulling...
T
Write your reply...
