Hyperion needs breaking in. Don't go by what the battery can do for the first 5 flights. The 6th flight, you will be scared of the head speed and power it'll give you
I get extreme power on that. And that battery is wayy better than turnigy nano tech. First hand comparison
And also the Thor 450 are good but not as good as hyperion .
And here is what I do for my charging of batteries.
I had a old mcpx charging harness lying around and I have removed the stupid blade connector and put micro deans on all batteries and esc so, I charge 6 battered at once at 2C.. 20 minutes and I am set to fly for an hour or so lol
You can also find these connectors at Rc-connectors (if I am not wrong) , they make pre pinched and made blade connector type spider connectors and I have used that too. I got one lying around that take 3 batteries .. Good part about those , they balance the cells too. I don't recommend not balancing them, but I am honestly not. I even removed the middle white wire from my connectors and so I am micro deans now all the way. It's so much better and easier and rated at 10a rather than blade's 3A
Again remember all good quality batteries now a days are needing a break in. So if you want your battery to create a punch .. Don't drain it first 4-5 times any more than 90 percent and charge it back up.. And then after that you are golden ! You'll see the huge power change.
Fly safe!!
have fun!
