I have reverted back to gx3.1 from 4 and the tail problem is cured locks and holds okay BUT!!!!!!!!!!!!!!!!!!!!!!!!!!!
now the heli will not lift off without attempting to tip over. I have re-done the pitch set up and I have zero degrees at centre stick with 10 degrees up and down
perfect has I can make it and the helicopter will not lift without tipping. I can not think of anything else. All things look level I have a swash tool now and thats
perfect but when I throttle up the swash is moving on its own. Could it be a vibration problem now. It did not exist when I was using version 4 so I would be surprised if this is the case.
This will be my last question on this helicopter. I am not getting the flight time in on this and it is giving me nothing but frustration so I will be changing brands and buying myself
a Blade 450. They are ready made out of the box so at least I will remember how to use the transmitter again. Any answers appreciated. Cheers
