So I got my first Ikon installed in my 300x. And it flies pretty good. Tail is rock solid.
But now when I flip the SL switch it pitches forward to the right agressively.
On the 300x the swash moves down for forward pitch and up for negative pitch.
This is backwards then almost all other helicopters. This is because the blade grips are reversed.
So on the pitch setting negative is positive and positive is negative. Hope that makes sense.
On the bench without the motor running I can flip the self level and see it go forward to the right.
Now I know we can adjust this in the advanced features under elevator and aileron level.
My question is should I see it pitching while on the bench. Or is this something that must be tested while flying and then make a small change?
