  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Flight Controllers I Need Helpppp
Discussion in 'Multi-Rotor' started by Cirilo Escandon, Dec 14, 2017.
< Best Cheap All In One Fc | Helppp >
  1. Cirilo Escandon
    Cirilo Escandon New Member
    Blog Posts:
    0
    Dec 14, 2017
    14
    0
    1
    Gender:
    Male
    georgisa
    I have a naze 32 rev6 with cleanflight on it. It is able to connect and everything but when I go to transmitter and turn on my transmitter it shows no signs that a transmitter is connected I even rebinded my Rx and TX but it's still not working can anyone help?
  2. Tony
    Blog Posts:
    14
    Feb 21, 2011
    36,233
    1,409
    113
    Make sure in the ports tab that you have the correct UART turned on for your Rx and that under the Configuration tab that you have the correct Rx listed.
  3. Cirilo Escandon
    Blog Posts:
    0
    Dec 14, 2017
    14
    0
    1
    Gender:
    Male
    georgisa
    I already made sure of that but still not working.
  4. rdsok
    rdsok Well-Known Member
    Blog Posts:
    0
    Sep 11, 2011
    1,588
    60
    48
    Norman, Ok USA
    Check that the USB cable is good and is a data type... not a charge/power only USB cable.
  5. Cirilo Escandon
    Blog Posts:
    0
    Dec 14, 2017
    14
    0
    1
    Gender:
    Male
    georgisa
    Yes it is a data type cable
  6. Admiral
    Admiral Well-Known Member
    Blog Posts:
    0
    Mar 2, 2014
    1,995
    123
    73
    Gender:
    Male
    Occupation:
    Information Technology (Retired)
    Brisbane, Australia
    If the Cleanflight can see the Naze unit & the Tx is bound to the Rx OK it must be the connection between the Rx and the unit.
    How are they connected PPM (1 Wire) , PWM (Several wires) , SBUS or MSP ?
    Check on the Configuration page under Receiver that the correct protocol is selected.
  7. Cirilo Escandon
    Blog Posts:
    0
    Dec 14, 2017
    14
    0
    1
    Gender:
    Male
    georgisa
    It's connected by pwm
  8. Admiral
    Blog Posts:
    0
    Mar 2, 2014
    1,995
    123
    73
    Gender:
    Male
    Occupation:
    Brisbane, Australia
    Is PWM selected on the configuration page ?
    Are all the wires in the correct order?
  9. Cirilo Escandon
    Blog Posts:
    0
    Dec 14, 2017
    14
    0
    1
    Gender:
    Male
    georgisa
    I will check
  10. Admiral
    Blog Posts:
    0
    Mar 2, 2014
    1,995
    123
    73
    Gender:
    Male
    Occupation:
    Brisbane, Australia
    Pining is normally
    1 = Aileron
    2 = Elevator
    3 = Throttle
    4 = Rudder
    5 = Aux #1
    6 = Aux #2
    7 = Aux #3
    7 = Aux #4
    But check the manual for your board.
  11. Tony
    Blog Posts:
    14
    Feb 21, 2011
    36,233
    1,409
    113
    Moved this to the correct section.
Share This Page
