I don't even know where to start with this friggin thing. To start off with, most of the screws that were going into plastic were stripped when I got it. The tail boom seems like it's made to fit another helicopter because it needs so much modification just to fit correctly. The head block is too big for the main shaft and sits there and wobbles back and forth, the plastic links on the head are not the same length so setting up the head is impossible. The links fit loose on the balls so you are always worrying about them flying off and when they do, a crash is coming.
I was just outside trying to get this thing dialed in and fighting it just like I did on the first flight. I came in, reweighed the blades, had to add over 5g to one of them, set the cog on them and tried again, this whole time, the tail is doing nothing but bouncing around and will not hold still. Nothing binding, so it's the vibration of the heli, the gyro or the tail servo causing it.
As I I have sitting on the ground just wagging like crazy, I hear a sound I had never heard before. It was the damn tail blade and grip and it went ripping right past my ear. That was the last straw.
I'm taking all of my electronics out of this helicopter and I'm trashing it. It's worth NOTHING with everything that is wrong with it. I'm DONE with clones!
