  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Projects Goblin 570 Sport
Discussion in 'Helicopters' started by brian ebling, Mar 30, 2019.
< No Human Should Be Able To Do This...insane Flight | Dx6 >
  1. brian ebling
    brian ebling New Member
    Mar 30, 2019
    4
    0
    1
    Gender:
    Male
    myerstown pa
    Hi I'm looking for some info on setting for my transmitter ,I have a spektrum dxm8 g2 and want I'm looking for are pitch curve ,throttle setup and other setting to put the radio for the goblin 570 sport to start with .thank you
  2. murankar
    Dec 4, 2011
    9,085
    380
    83
    Gender:
    Male
    Occupation:
    Soldier
    Eastlake, Ohio
    I have mine on vcontrol and a governor. I run the Vbar Neo governor .
    You probably should run a governor on it or run v curves. Your v curve will need to be set at an output value that will achieve the desired head Speed . For instance lets st you want 2000 rpm and at that head you need 80% throttle. Then your v curve will be at 80 80 75 80 80.
    I run a 0 25 50 75 100 pitch curve because that what the Vcontrol and Vbar neo use for all 3 IU settings.
    Back when I first starting fly in my IU 1 bank would be 45 47 50 75 100. My other 2 IU banks would be 0 25 50 75 100.
    Let us know what FBL unit you have and if your running a governor. For head speeds on a governor I would shoot for 1800 2000 2200 for your IU banks or if you like higher heed speeds then I would go 2000 2200 2400. Pro pilots will run around 2700 max. I use the lower set on a 12s 3000 or 3300 set up And net between 6.5 and 7.5 minutes at the 1800 head Speed. If you go to 2500 don't expect more that, maybe5 minutes of flight time.
  3. Tony
    Feb 21, 2011
    37,077
    1,454
    113
    If you are going to run a governor, set your throttle curves to match the RPM you want to use.
    Pitch settings, set them linear. If you want a normal mode with limited negative pitch you can do what URI posted above, but I use 46 48 50 75 100. My OCD says it's more logical lmao.
    For throttle curves not using a governor, set Normal to 0 70 70 70 70, iu1 to a flat 83 and iu2 to a flat 95. This will allow you to put in a little V Curve if you notice some bogging on collective pitch pumps.
  4. murankar
    Dec 4, 2011
    9,085
    380
    83
    Gender:
    Male
    Occupation:
    Soldier
    Eastlake, Ohio
    I edited the post so it made more sense.
  5. Tony
    Feb 21, 2011
    37,077
    1,454
    113
    Excellent information URI, thank you.
  6. brian ebling
    Mar 30, 2019
    4
    0
    1
    Gender:
    Male
    myerstown pa
    Thanks for the help .I didn't buy a FBL yet .I'm still building it just put servo in .I'm looking at Spektrum AR 7210 unit .
  7. murankar
    Dec 4, 2011
    9,085
    380
    83
    Gender:
    Male
    Occupation:
    Soldier
    Eastlake, Ohio
    I am not to overly familiar with that unit. Tony did a series on it and that should get it flying. If you run a hobby wing then the internal governor will be an excellent choice for a governor. It's almost a set and forget deal.
  8. Tony
    Feb 21, 2011
    37,077
    1,454
    113
    Are you talking about the AR7200BX? Or are you talking about putting a separate Rx on a flybarless gyro? If so, what gyro are you going to go with?
  9. brian ebling
    Mar 30, 2019
    4
    0
    1
    Gender:
    Male
    myerstown pa
    yes I'm go with a AR7210 BX with a satellite ,and a hobby wing 120 esc .
  10. murankar
    Dec 4, 2011
    9,085
    380
    83
    Gender:
    Male
    Occupation:
    Soldier
    Eastlake, Ohio
    The hibbywing gov sto feature is what you can use to set the governor. Almost set and for get. Just read the manual on how to do It.
  11. brian ebling
    Mar 30, 2019
    4
    0
    1
    Gender:
    Male
    myerstown pa
    thanks for your help I'll let you guys know when I get ready to start it up .
Share This Page
