buel williams
does anyone have the scoop on the tgz380
thanks for the heads up matt. I was asking because its so cheap and I heard it is a clone and some guys got duds more than onceI have one, and it is exactly like the MicroBeast Plus. Same size and everything. To set it up, just download the manual for the MicroBeast and you are golden.
thats good to know, thanks tony. will it work with sat recirver.It's definitely a possibility to get a dud, but I have not heard of many with this gyro.
right brother i have two already ordered,thanks agian
understood hope i dont get a dudNice. All that adapter is, is an adapter to go from the servo plug to the plug on the satellite, and most importantly, it is a 5v to 3.3 volt converter since spektrum satellites work on 3.3 volts.
