500 Fbl Unit
It looks like a Microbeast clone, so I'm assuming it is set up the same way a Microbeast is set up..
I have one, and it is exactly like the MicroBeast Plus. Same size and everything. To set it up, just download the manual for the MicroBeast and you are golden.
thanks for the heads up matt. I was asking because its so cheap and I heard it is a clone and some guys got duds more than once
It's definitely a possibility to get a dud, but I have not heard of many with this gyro.
Nice. All that adapter is, is an adapter to go from the servo plug to the plug on the satellite, and most importantly, it is a 5v to 3.3 volt converter since spektrum satellites work on 3.3 volts.
