coolgabsi
Super Mod & DEAL KING!
Tony!! Man m in trouble. The 450 build has started ok ok... I think I spoiled a servo by touching blue thread locker to it, the hole where it sits is withering.
Took my head assembly off to work on the rest of the heli like lock titing and all, but now I am noticing a considerable wobble in the main gear so much so that I tried mounting the motor I can see the pinion making contact and then getting less contact, tried the revisit paper thing but this wobble is killing me..
Exi managed to strip one of my h screws in body. Totally circular, can't even unscrew it. Donno what to do. Not so important but still...
Couldn't get any ball links to open. All too tight, so didn't bother trying too mich they were just getting stripped, wanted to locktite but couldn't, don't know now if it's good or bad.
The tail. I tried taking screws out one by one.. Well, didn't just strip a few, but it seems a little tight. I put all washers in place, and also tried loosening some, it helps but I have nothing to compare to the smoothness of tail pitch servo arm.
That's the major ones till now.
Can I fix my servo by using some material, or do I just order a new one? I am just scared to put anything else on it... I knew I should have had a spare for servos... (dang it!!)
Also the tail servo Arm is too long if I put those clamps to lout the servo on. How to shorten them?
What time are you on chat on this forum now? It'd be great if I xxould talk to you!! Or someone! Thanks man!
Help me!!!!
Help me!!!!
