I am fairly new to the hobby and this is my first post. I have been searching the forums and can't seem to find the answers I am looking for. I have a freshly built Synergy N5c w/ an OS 55 HZ-R DRS.....I have not even fired this thing up. I am to scared too do so until I know I am not going to blow the motor. I am running the AR7200BX and have the Spektrum rpm/governor sensor. The only guys locally that I have met run Futaba and really can't help with my Spektrum/Beast X set-up. I have gone through the parameter menu and the governor menu on the AR7200BX and have it setup per the instructions, I also verified by turning over the motor by hand that the sensor is working/sensing the crank.....so here are my ?'s.
How does the sensor work? (I was told that it is not actually a governor like others on the market)
The DX9 governor menu just has percentages for flight modes(Normal, Stunt 1 & Stunt 2). How do I know what % to set to get a certain Head Speed/RPM......like 1850 or 2000???
What should my RPM/Head Speeds be???.......I can kind of do fly-bys, so 3D is not even a factor.
What should my throttle curves be in the DX9??
Does anyone have any suggestions on a tried & true break-in method?
