luciandrew
Ok guys, here is my question. regardless of which plane you purchase,the manual will state the control throw distances recommended for high and low rates,usually in mm's or increments of an inch(7/16,1/2 etc.). So in the travel adj settings,a specific %(let's say, 80% for elev) may correspond to 1/2 inch up and down for high rate. Once I adjust all the throw %'s for each control surface and let's say these are for high rates,then I can go to dual rate/expo adjustments to set dual rates. I would use position 1 on the aileron,elevator and rudder set to 100% for my high rate,this would keep my previous settings intact from the travel adj correct? then position 0 on these switches would be set at some lower % to achieve low rates stated in the manual.( Keep adjusting % and measuring throws). Am I correct on this? Also,since expo settings may not be mentioned in the manual,what would be a good starting point (+50%) ?
Thanks, Jeff from Ohio.
