I actually have all the electronics for this plane that I want, except for the ESC. I do have the Hobbywing 100amp esc, from my previous project plane, but since I want to run a 12S battery setup on this plane...the Hobbywing esc just isn't going to work.
I've gone back and watched Tony's (forum owner, lol) on Matching the motor to the esc to the battery. Very educational video!!! I want to run some numbers past you all and see if I'm thinking about this correctly.
For the batteries:
Tony is saying to find the Amp rating that the batteries will put out, to follow this equation:
MAH x C rating / 1000 = Max amps that the batteries will put out
So, I'm wanting to run two 6S 3700mah 35C lipos
that would be 3700 x 35 / 1000 = 129.5 amps Am I thinking this correctly?
Tony is also saying, for the motor, take the watts from the motor specs and divide that by the battery voltage to find the amps needed for a proper ESC. I'm using my Tacon Bigfoot 160 245kv motor from Hobbypartz.com. The specs say 2700 watts
so, that would be watts / battery voltage = motor amps
2700/44.4= 60.81amps
All that being said, I'd be very safe with a Castle HV 80amp esc. Right?
