If one of the flybar paddles is pointing up that could throw it out of balance and in turn cause a vibration. Plus, if the flybar, or any of the head parts don't move smoothly it can definitely cause a vibration.
Unless you need to remove the bolts, I wouldn't worry about them. The person you got it from probably loctited the he'll out of them. Tight bolts is actually a good thing, of course like I said, until you need to remove them. A 450 has a lot of power and if your bolts aren't tight/loctited, then you take the chance of bolts loosening up or falling out completely, which could be disastrous. ANY bolt that goes into metal should have loctite on them.
Also, you don't want the blades too tight, but, like Mathias said, you don't want them too loose either. You kinda have to find that sweet spot somewhere in the middle. They should be equally tight enough so they don't flop around but loose enough that you can still move them by hand. A little trick I use is tighten them to the point that if you tilt the heli on its side they stay stretched out, then give the heli 1 good shake and the blades should fall, or fold up.
