If the throttle goes to full power when you turn off the Tx then you have the failsafe set wrong. To fix this you need to re-bind. When binding always make sure that throttle on the Tx is fully closed as it's during the bind process that the failsafe position is learned.
If the motor spins the wrong way then swap over any two of the three wires between ESC and motor.
That worked for about 3 minutes. I have had this thing working and suddenly it started doing all kinds of quirky things. Motor works, motor doesn't, motor chatters at low stick, BEC voltage disappears then comes back.
Well to make a short story long. I rebound it. I turned on the TX, I turn on the hele, it binds, no motor at low stick. Swash movements good. Took motor to idle, GREAT. I let it idle for about three minutes and decide to run the motor up. ESC smokes. Now I don't trust the motor. I have another ESC and motor and I'm thinking about changing out motor too. I did hook up a battery to the ESC (without the motor) after I ripped it out of the bird and it still smoked but still had BEC..
What just happened???
