Hello well after reading a lot of post about blade pitch, I am still missing something,
I have a Blade 400 with updated servos fabatu all round and a gyro 401. every arm is set at 90 to servos.
after going in and setting every thing up from the manual, I cannot seem to get my pitch settings correct,
all servo arms are set with a caliper, and my swah plate setting are left side 59.35mm right side 59,53mm and front 16.35mm all should be 16.25mm , all blade are set at mid pitch . with a manual pitch gauge.
blade 1 0 pitch =+4 positive pitch =+ 11 and negative pitch = -1
blade 2 0 pitch= +2 positive pitch =+ 11 and negative pitch = +1
I have a x6i transmitter here are some settings
swash mix -75% -75% +85. swash type ccpm 120. thro cut ACT.
D/R expo D/R EXPO Gyro rate sw-gyro
aile 1 = 80% aile 0 100% + 30 0: 70%
elev1 = 80% elev 0 100% +30 1: 40.5%
rudd 1= 70% rudd 0 100% +30
THRO CUR
NORM 0.0% 42.5% 60.0% 80.0% 100.0%. PITCH Cur Norm 35.0% 42.5% 50.0% 75.0% 100.0%
THANK YOU FOR LOOKING
THRO CUR
