  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Cases Battery Storage
Discussion in 'Electronics' started by bigone5500, Feb 9, 2018.
< Castle 25 Amp | Multiple Escs >
  1. bigone5500
    bigone5500 Well-Known Member
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    I recently got a good deal on some 50cal ammo cans at walmart. I thought I'd post how I did my insides. I used some scrap foam I got at work and lined the can and created some partitions. I can store 15 of these 1550mAh batteries. I used a piece of the foam to cover the battery leads so they don't touch the metal lid.
    I don't have many stickers for box bling but I'm sure these will do just fine!
  2. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    P.S. - The foam is 15mm thick.
  3. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    Putting random batteries in the other can. I just cut pockets for them.
  4. Tony
    Feb 21, 2011
    37,148
    1,458
    113
    Looks like that needs a white background on the RCH logo lol. Looking good though. Try the last post again, it didn't take for some reason.
  5. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    I will need to get some thin foam for the sides on the last one. I don't like those connectors touching metal.
  6. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    I actually think the RCH logo looks good on the dark green. That photo doesn't do it justice. It's really brighter in person.
  7. Tony
    Feb 21, 2011
    37,148
    1,458
    113
    I just see that picture and first thing I think of is a shadow in white or light gray. Would look sick as...
  8. rdsok
    rdsok Well-Known Member
    Sep 11, 2011
    1,822
    70
    48
    Norman, Ok USA
    Just make certain the boxes don't seal and can vent... otherwise if a battery fails you may end up with a square pipe bomb
    liquid1 likes this.
  9. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    They do have seals. I can remove them though. Either that or add holes.
  10. liquid1
    liquid1 Member
    Dec 25, 2017
    279
    11
    18
    Gender:
    Male
    Occupation:
    Mobile hydraulic technician
    mooresville nc
    Cool idea I was thinking about what rdsok said prob drill vent holes. Where did you get your foam from??
  11. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    The foam was packing material for something at work. It's not regular foam. I think it's PP or PE.
  12. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    I just want to rant about this foam I used. I hate it. I FREAKING HATE IT! Yes, it looks pretty good but I want to secure it so the partitions don't move around. I have absolutely no glue except for hot glue that will somewhat adhere it. Even then, the hot glue melts it almost to the point that I can't get the pieces to stick due to it melting down into the foam. I will be using some regular foam from now on. Something with smaller pores that can accept double sided tape. Polypropylene foam is almost impossible to adhere to. Packing material...that's all it's good for.
    liquid1 likes this.
  13. Tony
    Feb 21, 2011
    37,148
    1,458
    113
    lol, my first thought was you could cut slots for the separators to fit and slide into. Then no glue needed.
  14. Admiral
    Admiral Well-Known Member
    Mar 2, 2014
    2,149
    128
    73
    Gender:
    Male
    Occupation:
    Information Technology (Retired)
    Brisbane, Australia
    I use a product called SikaBond - TechGrip in Australia which is a Polyurethane glue, I think it is available in the USA under the name SikaBond - Ultimate Grab.
    I use it on a similar foam to you are using only white in color.
    Multipurpose Adhesives 02a024sa017
  15. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    I wonder if that's the same stuff as Liquid Nails? Does it have a vinegar odor like silicone?
    Ultra Qwik GRIP Adhesive
  16. Tony
    Feb 21, 2011
    37,148
    1,458
    113
    You could use silicone... just sayin' :chuckles:
  17. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    Silicone is one of the adhesives I didn't think about actually. But the stuff I have has vinegar in it and I would be worried about corrosion from the fumes.
  18. Tony
    Feb 21, 2011
    37,148
    1,458
    113
    That smell will go away once it is cured.
  19. Admiral
    Mar 2, 2014
    2,149
    128
    73
    Gender:
    Male
    Occupation:
    Brisbane, Australia
    No it has kind of a sweet smell ! hard to describe.
  20. bigone5500
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    I was at hobby lobby over the weekend and found some glue that I wanted to try. It claimed to adhere foam. To my surprise it does the job very well. Matter of fact, it is made for the type foam I have in my ammo cans. EPP foam. $5.99.
    liquid1 likes this.
Share This Page
