trainrider06
I thought I'd do a little thread to try and help others in case they ran into some things as I have with this build....
I bought this heli with pretty much a frame/tail/and head, have so far done quite a bit of work to it. But here are the first few pix of it as I got it....filthy dirty, and pretty abused! It looked like it was crashed a few times over, but amazingly the frame and structure integrity remained in good shape. I did replace the left side frame because the previous owner, had ground and butchered the plastic part of the tail boom attached to the frame itself in an effort to remove a stuck screw....this turned out to be something I'd have to deal with many times during complete disassembly.
This bearing block you can see just how filthy this thing was. The bearings I didn't even bother with as far as cleaning, they were replaced!
Here you can see what I was talking about where the plastic area, I guess reinforcement piece is cut all up by the screw removal effort of the previous owner.
In all, I had 9 stuck screws in this frame!
This is what I had to use to remove them, the frame will suffer some scratching around the screw holes, but it's unavoidable.
This is also why one should not use button head screws that have to have any kind of torque at all applied during assembly. The best thing anyone can do is throw the button head screws away, and use cap screws!
They are much more sturdy, and if one happens to strip on you, then there is enough of a head to get a grip on in order to remove them!
