PLANETGETLOW
Banned
As some of you may or may not know I've been building this 450l for about 2 weeks and finally got it assembled. Upon spoiling it up I noticed a bad wobble and my gyro and Servo reversed after fixing the gyro and servo the head was still wobbling very severe which caused a main Blade to boom strike.
I then pulled the head off and spooled it up only to notice that the main shaft was bent. Please keep in mind that this helicopter has never been hovered so this main shaft was bent right from the manufacturer. I went and purchased another main shaft that had a locking bearing which was nice because it allowed me to make a tighter tolerance between the top of the frame on main gear so there is maybe 1mm of slack.
I then put the head back on and took it for a test hover/spool up, which it hovered spooled up and hovered fine but when it's spooled down the vibration came back almost to the extent of causing a blade to ground strike. Maybe i came off ofmthe throttle too fast?
This prompted me to bring the helicopter back in and pull the head completely apart and inspect the Feathering spindle and the rest of the components. This prompted me to bring the helicopter back in and pull the head completely apart and inspect the feather and spend all and the rest of the components. When I finally got it all torn apart the feathering shaft was fine it was not bent however I forgot to Lube the bearings.
I now have it all back together and did a bench tests pool up everything seemed fine so I went ahead and put the main blades on and I'm letting the locktite setup before i try it again.
In the meantime I've been reading that the main shafts on these for 450s are very fragile has anybody else experience this? I've read to the extent that a hard landing could even cause a been making shaft?
Would coming off of the throttle too fast cause a bad wobble? Has anybody else had main shaft issues?
