Re: 120SR & Blade 450 3D
I have created a model for B450 3D & I have entered the seetings that is in the manual that came with the B450 3D.
I then made a model for 120SR and copied the setting for B450 3D in that model and changed the swash type to 90 degree for the 120SR.
120SR has one servo.
Where do I go from here.
Good.
Now you'll just have to bind the Tx to the Rx.
Before commencing, turn all your switches to 0.
Start with the 450, as we know this helicopter has binded with your DX6i previously.
Before powering up the 450, pull up your Tx.
Choose the 450 in your "Model Select", then turn off your Tx.
Find the Rx on your 450, and locate a port that's called "BIND" (name may vary, but "bind" is on there somewhere).
Insert your bind plug into the bind port on the Rx.
Lower the throttle stick on your Tx (THIS IS IMPERATIVE).
On the back side of your Tx there is a "BIND" button.
Hold the bind button as you switch ON your Tx. The Tx will say "Binding" on the screen.
Now power up your 450.
You'll know when the binding is complete (the light on your Rx should stay constant lit).
I think you should be able to move the right control stick now, and there will be movement of the servos.
Disconnect the 450. Take out bind plug.
Bind completed!
The steps are the same for the 120SR.
If there is a fairly advanced Rx on your 120SR, it too should have a bind port, and a bind plug.
If not, there should be a bind button on the Rx.
I'm not familiar with the 120SR, so there is a bit of speculation from my side.
On your Phoenix flight simulator, there is no bind process.
Only make sure you set the values I provided in my previous post.
Just choose the "Simulator" from your "Model Select" screen before connecting the Tx to your computer.
Please try this, then come back.
