Hey all, I used Tony videos on setting up 450 heli using 45a Yep for a 3s motor. On a 6s motor=1800Kv the timing specs on this motor is 5 Degrees. I'm using a 60a yep on my Gaui X3. My question is if my timing is lowered from 18 degrees on my 3s motor=3850Kv to 6 degrees on my 6s motor=1800Kv "no 5 so round up to 6" and the PWM went from 10Hz on the 3s to 8Hz on the 6s. Does my P/I gain and my cut off voltage change also? I can use some help with some numbers if anyone can understand what I'm talking about.
