1. Guest, Thank you for visiting Rc-Help. Please do NOT post tech questions in this section, post them in the Tech section instead. Thank you.
    Dismiss Notice
  2. If you would like to get rid of these banners and the ads within the posts, all you have to do is sign up and they will go away!
  3. Welcome to Rc-Help, are you here looking for the PDF Plans? They are located in the store in the tab above, but you must be signed in to access that part of the site. It only takes a second to sign up!
  4. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Wltoys 12428 Battery Charger Suggestion
Discussion in 'RC-Help Lounge' started by Christian30, Feb 10, 2020.
< Happy Valentines Day!!! | Anyone Into Freshwater Aquariums ? >
  1. Christian30
    Christian30 New Member
    Feb 10, 2020
    1
    0
    1
    Pakistan
    Hi I'm new here and I'm also totally new to RC hobby. I just bought my first ever RC (Wltoys 12428) and I really love it but there's only one thing that I don't like which is the battery charger. it is a USB charger and it takes around 5 hours to charge the battery and I have to keep my laptop turn on just for that.
    is there any decent AC charger NOT very expensive that I can buy from Aliexpress?
    Thanks
  2. Tony
    Feb 21, 2011
    37,144
    1,458
    113
    There are quite a few of them, and they are all pretty much the same. Just pick one out and post it up and we can advise if it will be worth it or not.
  3. murankar
    Dec 4, 2011
    9,222
    388
    83
    Gender:
    Male
    Occupation:
    Soldier
    Eastlake, Ohio
    Until that comes in find one if those high amps wall charges for cell phones. Just the brick with a USB port. That way you can get at least 2 to 3 amps and speed things up.
    Most of the 4 button chargers are the same design with different branding. As stated they all will work for your current situation. Also dont go ove 1c charge rate for that battery. You can set the charge rate with those chargers. So dont over do it.
    I can't remember the equation at the moment but you can do some really light math and figure out your charge rate.
Share This Page
