mooserider
Hi all, it's been a while! Started working on my biplane again and ran into a problem. It comes with four pieces of 'silver wire' used for wrapping the cabane struts and the split elevator push rod pieces. I forgot to put some inner pushrod pieces on the elevator push rods before soldering it all together, so I need to redo it and need another wire for wrapping it up before soldering. Is there anything special about this wire? My wife had a great idea... to use the wire from pipe cleaner or twist ties. They're about the right thickness and flexibility. So long as I clean them really well and it sticks when soldered, are there any concerns? Of course it would suck bad to have the elevator push rods come loose during flight!
Thanks for any advice!
