FBL Gyro What's the Difference Between These 2
I've not used one but as i understand it the technology is exactly the same, just a smaller case. The adapters solve the servo problem so you should be good to go.
the biggest heli that gyro will handle is 325mm blades. It might handle 360mm baldes, not 100% sure on that.
