Personally I would not use 3-in-1. I'd use a bearing oil specifically made for high rpm, high load bearings. 3-in-1 is more of a general purpose lubricant for relatively low load, low temperature applications. You may be able to get away with it on main shaft and tail bearings, but I would definitely not use it on motor bearings or any motor shaft support bearings.
