Hi RC HELPERS,
I need to buy some linkage wire to connect the control surface servos and horns on my WIlga 2000 The holes in the horns is .064 I see 4-40 and 2-56 rods by du-bro but there is no mention of the wire thickness.
Tom the NOOB
The Wilga's Specs:
Motor: SP2830-26 brushless
Battery: 11.1 v Li-po battery
ESC: 25a
Wingspan: 45.6 in. (1160 mm)
Length: 34.8 in. (888 mm)
Weight: (600g)
Propeller: 8 x 6 tri-blade propeller
Construction: Foam
Servos: 3x9G
Horns: Du-bro 1/2 A Control Horns #107
Tom the NOOB
The Wilga's Specs:
ESC: 25a
Weight: (600g)
Construction: Foam
Servos: 3x9G
