I have done some reading around and I'm seeing people using anything from a 1000mah 3s to a 2200mah 3s battery on their quad. Most are using 1300mah to 1800mah. But my question to you is, what exact battery are you using on your 250, why are you using that battery, and what kind of flight times are you getting?
I'm seeing the Zippy Compacts being used quite a lot so I'm lookign at those, but I'm also seeing others that are coming up.
Post what you think I should use on this bird.
